Datasheet Texas Instruments 74ALVCH162260DLRG4 — Даташит
СерияSN74ALVCH162260
Модель74ALVCH162260DLRG4
Мультиплексная защелка D-типа с разрядностью от 12 до 24 бит с выходами с 3 состояниями 56-SSOP от -40 до 85
SN74ALVCH162260 datasheet
PDF, 352 Кб, Версия: I, Файл опубликован: 5 авг 2004
Микросхема Логический замок, 12Bit To 24Bit Multiplexed D-Type Latch With 3-State Outputs 56-SSOP -40℃ to 85℃
74ALVCH162260DLRG4
49 ₽
TradeElectronics
74ALVCH162260DLRG4
74ALVCH162260DLRG4
74ALVCH162260DLRG4
Pin56
Package TypeDL
Industry STD TermSSOP
Package QTY1000
МаркировкаALVCH162260
Width (мм)7.49
Length (мм)18.41
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
3-State OutputYes
Bits12
F @ Nom Voltage(Max)150 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)24/-24 мА
Package GroupSSOP
Package Size: mm2:W x L56SSOP: 191 mm2: 10.35 x 18.42(SSOP) PKG
Schmitt TriggerNo
Technology FamilyALVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)5.9,5.8,4.9 нс
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Live Insertion
  • Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Latch
На английском языке: Datasheet Texas Instruments 74ALVCH162260DLRG4
