Datasheet Texas Instruments SN74ALVCH16601DGGR — Даташит
| Серия | SN74ALVCH16601 |
| Модель | SN74ALVCH16601DGGR |
18-битный универсальный шинный трансивер с выходами с 3 состояниями 56-TSSOP от -40 до 85
SN74ALVCH16601 datasheet
PDF, 368 Кб, Версия: F, Файл опубликован: 27 авг 2004
|  Купить SN74ALVCH16601DGGR на РадиоЛоцман.Цены — от 19 до 207 ₽ 26 предложений от 16 поставщиков Микросхема Логический контроллер, 18Bit Universal Bus Transceiver With 3-State Outputs 56-TSSOP -40℃ to 85℃ | |||
| SN74ALVCH16601DGGR Texas Instruments | 163 ₽ | ||
| SN74ALVCH16601DGGR Texas Instruments | от 206 ₽ | ||
| SN74ALVCH16601DGGR Texas Instruments | от 207 ₽ | ||
| SN74ALVCH16601DGGR Texas Instruments | по запросу | ||
| Pin | 56 |
| Package Type | DGG |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | ALVCH16601 |
| Width (мм) | 6.1 |
| Length (мм) | 14 |
| Thickness (мм) | 1.15 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 18 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.04 мА |
| Output Drive (IOL/IOH)(Max) | -24/24 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 56TSSOP: 113 mm2: 8.1 x 14(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | ALVC |
| VCC(Max) | 3.6 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 3.3 В |
| tpd @ Nom Voltage(Max) | 5 нс |
- TI SN74ALVC16835 Component Specification Analysis for PC100PDF, 43 Кб, Файл опубликован: 3 авг 1998
 The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
- Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
 Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
- Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
 When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
- 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
- Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
 In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
Серия: SN74ALVCH16601 (3)
- SN74ALVCH16601DGGR SN74ALVCH16601DL SN74ALVCH16601DLR
- Semiconductors > Logic > Universal Bus Function > Universal Bus Transceiver (UBT)
