Datasheet Texas Instruments SN74ALVCH16835DGVR — Даташит
СерияSN74ALVCH16835
МодельSN74ALVCH16835DGVR
18-битный универсальный драйвер шины с выходами с 3 состояниями 56-TVSOP от -40 до 85
SN74ALVCH16835 datasheet
PDF, 772 Кб, Версия: J, Файл опубликован: 2 сен 2004
Pin56
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаVH835
Width (мм)4.4
Length (мм)11.3
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
F @ Nom Voltage(Max)150 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Package GroupTVSOP
Package Size: mm2:W x L56TVSOP: 72 mm2: 6.4 x 11.3(TVSOP) PKG
Schmitt TriggerNo
Technology FamilyALVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)5,4.9,4.2 нс
  • Timing Differences of 10-pF Versus 50pF Loading
    PDF, 47 Кб, Файл опубликован: 1 ноя 1996
    The 'ALVCH16244 is a 16-bit advanced low voltage CMOS (ALVC) unidirectional driver. Typically, data sheet values for tpd, ten, and tdis are characterized under a 50-pF capacitive load with a temperature range of -40?C to 85?C. At times these drivers are used in memory addressing for dual in-line memory modules (DIMM) with a 10-pF load and and temperature range of 0?C to 70?C. This document provide
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
Серия: SN74ALVCH16835 (2)
  • Semiconductors > Logic > Universal Bus Function > Universal Bus Driver (UBD)
На английском языке: Datasheet Texas Instruments SN74ALVCH16835DGVR
