Datasheet ТI SN74ALVCHS162830A — Даташит
СерияSN74ALVCHS162830A
Datasheet Texas Instruments SN74ALVCHS162830A
Драйвер адреса от 1 до 2 бит с выходами с 3 состояниями
74ALVCHS162830A datasheet
PDF, 281 Кб, Файл опубликован: 9 фев 2005
74ALVCHS162830AGRALVCHS162830AGRE4
Доступность образцов у производителяДаДа
N12
Pin8080
Package TypeDBBDBB
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаALVCHS162830AALVCHS162830A
Width (мм)6.16.1
Length (мм)1717
Thickness (мм)1.151.15
Pitch (мм).4.4
Max Height (мм)1.21.2
Parameters / Models74ALVCHS162830AGR
74ALVCHS162830AGR
ALVCHS162830AGRE4
ALVCHS162830AGRE4
Bits22
F @ Nom Voltage(Max), Mhz100100
ICC @ Nom Voltage(Max), мА0.20.2
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА-12/12-12/12
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG80TSSOP: 138 mm2: 8.1 x 17(TSSOP)80TSSOP: 138 mm2: 8.1 x 17(TSSOP)
RatingCatalogCatalog
Schmitt TriggerNoNo
Technology FamilyALVCALVC
VCC(Max), В3.63.6
VCC(Min), В2.32.3
Voltage(Nom), В1.8,2.5,2.7,3.31.8,2.5,2.7,3.3
tpd @ Nom Voltage(Max), нс3.8,4,3.53.8,4,3.5
RoHSСовместимСовместим
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Live Insertion
Серия: SN74ALVCHS162830A (2)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Non-Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74ALVCHS162830A
Политика конфиденциальности
