Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74ALVTH16601DL — Даташит
СерияSN74ALVTH16601
МодельSN74ALVTH16601DL
18-битный универсальный шинный приемопередатчик 2,5 В/3,3 В с выходами с 3 состояниями 56-SSOP от -40 до 85
2.5-V/3.3-V 18-Bit Universal Bus Transceiver With 3-State Outputs datasheet
PDF, 462 Кб, Версия: A, Файл опубликован: 12 июл 1999
Pin56
Package TypeDL
Industry STD TermSSOP
Package QTY20
МаркировкаALVTH16601
Width (мм)7.49
Length (мм)18.41
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Bits18
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Output Drive (IOL/IOH)(Max)-24/24,-32/64 мА
Package GroupSSOP
Package Size: mm2:W x L56SSOP: 191 mm2: 10.35 x 18.42(SSOP) PKG
Schmitt TriggerNo
Technology FamilyALVT
VCC(Max)3.6 В
VCC(Min)2.3 В
Voltage(Nom)2.5,3.3 В
tpd @ Nom Voltage(Max)4.8,3.9 нс
  • Advanced Low-Voltage Technology
    PDF, 59 Кб, Файл опубликован: 27 июл 1999
    ALVT, the advanced low-voltage logic family, offers high-performance BiCMOS devices that are functional at 3.3-V and 2.5-V V sub CC and have low propagation delay, low static-power consumption, and 64 mA current drive. Other features include 5-V tolerance; auto3-state; bus hold; partial power down, hot insertion, and live insertion; and excellent simultaneous-switching and output-skew performance.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Semiconductors > Logic > Universal Bus Function > Universal Bus Transceiver (UBT)
На английском языке: Datasheet Texas Instruments SN74ALVTH16601DL
