Datasheet ТI SN74AS169A — Даташит
| Серия | SN74AS169A |
Синхронные 4-битные двоичные счетчики с прямым/обратным увеличением
Synchronous 4-Bit Up/Down Binary Counters datasheet
PDF, 769 Кб, Версия: B, Файл опубликован: 1 дек 1994
| SN74AS169AN | |
| SN74AS169AN | |
| N | 1 |
| Pin | 16 |
| Package Type | N |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Package QTY | 25 |
| Carrier | TUBE |
| Маркировка | SN74AS169AN |
| Width (мм) | 6.35 |
| Length (мм) | 19.3 |
| Thickness (мм) | 3.9 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Parameters / Models | SN74AS169AN![]() |
| Bits | 4 |
| F @ Nom Voltage(Max), Mhz | 125 |
| Function | Counter |
| ICC @ Nom Voltage(Max), мА | 63 |
| Рабочий диапазон температур, C | от 0 до 70 |
| Output Drive (IOL/IOH)(Max), мА | 20/-2 |
| Package Group | PDIP |
| Package Size: mm2:W x L, PKG | See datasheet (PDIP) |
| Rating | Catalog |
| Technology Family | AS |
| Тип | Binary |
| VCC(Max), В | 5.5 |
| VCC(Min), В | 4.5 |
| Voltage(Nom), В | 5 |
| tpd @ Nom Voltage(Max), нс | 16.5 |
| SN74AS169AN | |
| Бессвинцовая технология (Pb Free) | Да |
- Advanced Schottky Load ManagementPDF, 277 Кб, Файл опубликован: 1 фев 1997
Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN74AS169A (1)
- Semiconductors> Logic> Specialty Logic> Counter/Arithmetic/Parity Function
