Datasheet Texas Instruments SN74AUC04 — Даташит
СерияSN74AUC04
Шестигранный инвертор
SN74AUC04 datasheet
PDF, 783 Кб, Файл опубликован: 3 июн 2003
SN74AUC04RGYR
Статус продуктаВ производстве
SN74AUC04RGYR
N1
Pin14
Package TypeRGY
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаMS04
Width (мм)3.5
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Parameters / ModelsSN74AUC04RGYR
SN74AUC04RGYR
Bits6
F @ Nom Voltage(Max), Mhz250
ICC @ Nom Voltage(Max), мА0.01
Рабочий диапазон температур, Cот -40 до 85
Output Drive (IOL/IOH)(Max), мА-9/9
Package GroupVQFN
Package Size: mm2:W x L, PKG14VQFN: 12 mm2: 3.5 x 3.5(VQFN)
Schmitt TriggerNo
Technology FamilyAUC
VCC(Max), В2.7
VCC(Min), В0.8
Voltage(Nom), В1.8,2.5
tpd @ Nom Voltage(Max), нс2.5,2
SN74AUC04RGYR
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUC04 (1)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74AUC04
