Datasheet Texas Instruments SN74AUC16373DGGR — Даташит
| Серия | SN74AUC16373 |
| Модель | SN74AUC16373DGGR |
16-битная прозрачная защелка типа D с выходами с 3 состояниями 48-TSSOP от -40 до 85
SN74AUC16373 datasheet
PDF, 389 Кб, Версия: C, Файл опубликован: 1 ноя 2002
Купить SN74AUC16373DGGR на РадиоЛоцман.Цены — от 34 до 304 ₽31 предложений от 14 поставщиков Микросхема Логический замок, 16Bit Transparent D-Type Latch With 3-State Outputs 48-TSSOP -40℃ to 85℃ | |||
| SN74AUC16373DGGR Texas Instruments | 219 ₽ | ||
| SN74AUC16373DGGR Texas Instruments | от 304 ₽ | ||
| SN74AUC16373DGGR Texas Instruments | по запросу | ||
| Pin | 48 |
| Package Type | DGG |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | AUC16373 |
| Width (мм) | 6.1 |
| Length (мм) | 12.5 |
| Thickness (мм) | 1.15 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| 3-State Output | Yes |
| Bits | 16 |
| F @ Nom Voltage(Max) | 250 Mhz |
| ICC @ Nom Voltage(Max) | 0.02 мА |
| Output Drive (IOL/IOH)(Max) | 9/-9 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | AUC |
| VCC(Max) | 2.7 В |
| VCC(Min) | 0.8 В |
| Voltage(Nom) | 0.8,1.2,1.5,1.8,2.5 В |
| tpd @ Nom Voltage(Max) | 8,3.8,2.4,1.9 нс |
- Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUC16373 (2)
- SN74AUC16373DGGR SN74AUC16373DGVR
- Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Latch
