Datasheet Texas Instruments CAUC1G125MDCKREP — Даташит
СерияSN74AUC1G125-EP
МодельCAUC1G125MDCKREP
Усовершенствованный продукт Буферный вентиль с одной шиной и выходом с 3 состояниями 5-SC70 от -55 до 125
SN74AUC1G125-EP datasheet
PDF, 211 Кб, Файл опубликован: 13 мар 2007
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаCAY
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputYes
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeBUFFER
ICC @ Nom Voltage(Max)0.01 мА
Тип входаCMOS
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Тип выходаCMOS
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)4.7,7.5,6,5.5,5 нс
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
Серия: SN74AUC1G125-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Little Logic Products
На английском языке: Datasheet Texas Instruments CAUC1G125MDCKREP
Публикации по теме
