Datasheet ТI SN74AUC244 — Даташит
| Серия | SN74AUC244 |
Восьмеричный буфер/драйвер с выходами с 3 состояниями
| SN74AUC244RGYR | SN74AUC244RGYRG4 | |
| Статус продукта | В производстве | В производстве |
| Доступность образцов у производителя | Да | Да |
| N | 1 | 2 |
| Pin | 20 | 20 |
| Package Type | RGY | RGY |
| Industry STD Term | VQFN | VQFN |
| JEDEC Code | R-PQFP-N | R-PQFP-N |
| Package QTY | 3000 | 3000 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | MS244 | MS244 |
| Width (мм) | 3.5 | 3.5 |
| Length (мм) | 4.5 | 4.5 |
| Thickness (мм) | .9 | .9 |
| Pitch (мм) | .5 | .5 |
| Max Height (мм) | 1 | 1 |
| Parameters / Models | SN74AUC244RGYR![]() | SN74AUC244RGYRG4![]() |
| Bits | 8 | 8 |
| F @ Nom Voltage(Max), Mhz | 250 | 250 |
| ICC @ Nom Voltage(Max), мА | 0.02 | 0.02 |
| Рабочий диапазон температур, C | от -40 до 85 | от -40 до 85 |
| Output Drive (IOL/IOH)(Max), мА | -9/9 | -9/9 |
| Package Group | VQFN | VQFN |
| Package Size: mm2:W x L, PKG | 20VQFN: 16 mm2: 3.5 x 4.5(VQFN) | 20VQFN: 16 mm2: 3.5 x 4.5(VQFN) |
| Rating | Catalog | Catalog |
| Schmitt Trigger | No | No |
| Technology Family | AUC | AUC |
| VCC(Max), В | 2.7 | 2.7 |
| VCC(Min), В | 0.8 | 0.8 |
| Voltage(Nom), В | 0.8,1.2,1.5,1.8,2.5 | 0.8,1.2,1.5,1.8,2.5 |
| tpd @ Nom Voltage(Max), нс | 6.5,3.7,2.3,1.9,1.5 | 6.5,3.7,2.3,1.9,1.5 |
| RoHS | Совместим | Совместим |
- Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUC244 (2)
- Semiconductors> Logic> Buffer/Driver/Transceiver> Non-Inverting Buffer/Driver
