Datasheet ТI SN74AUC245 — Даташит
| Серия | SN74AUC245 |
Восьмеричный шинный трансивер с выходами с 3 состояниями
| SN74AUC245RGYR | SN74AUC245ZQNR | |
| Статус продукта | В производстве | В производстве |
| Доступность образцов у производителя | Да | Да |
| N | 1 | 2 |
| Pin | 20 | 20 |
| Package Type | RGY | ZQN |
| Industry STD Term | VQFN | BGA MICROSTAR JUNIOR |
| JEDEC Code | R-PQFP-N | R-PBGA-N |
| Package QTY | 3000 | 1000 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | MS245 | MS245 |
| Width (мм) | 3.5 | 3 |
| Length (мм) | 4.5 | 4 |
| Thickness (мм) | .9 | .75 |
| Pitch (мм) | .5 | .65 |
| Max Height (мм) | 1 | 1 |
| Parameters / Models | SN74AUC245RGYR![]() | SN74AUC245ZQNR![]() |
| Bits | 8 | 8 |
| F @ Nom Voltage(Max), Mhz | 250 | 250 |
| ICC @ Nom Voltage(Max), мА | 0.02 | 0.02 |
| Рабочий диапазон температур, C | от -40 до 85 | от -40 до 85 |
| Output Drive (IOL/IOH)(Max), мА | -9/9 | -9/9 |
| Package Group | VQFN | BGA MICROSTAR JUNIOR |
| Package Size: mm2:W x L, PKG | 20VQFN: 16 mm2: 3.5 x 4.5(VQFN) | 20BGA MICROSTAR JUNIOR: 12 mm2: 3 x 4(BGA MICROSTAR JUNIOR) |
| Rating | Catalog | Catalog |
| Schmitt Trigger | No | No |
| Technology Family | AUC | AUC |
| VCC(Max), В | 2.7 | 2.7 |
| VCC(Min), В | 0.8 | 0.8 |
| Voltage(Nom), В | 0.8,1.2,1.5,1.8,2.5 | 0.8,1.2,1.5,1.8,2.5 |
| tpd @ Nom Voltage(Max), нс | 5,3.3,2,1.7,1.4 | 5,3.3,2,1.7,1.4 |
| RoHS | Совместим | Совместим |
- Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUC245 (2)
- Semiconductors> Logic> Buffer/Driver/Transceiver> Standard Transceiver
