Datasheet Texas Instruments SN74AUC2G126 — Даташит
СерияSN74AUC2G126
Буферный вентиль с двойной шиной и выходами с 3 состояниями
SN74AUC2G126 datasheet
PDF, 809 Кб, Версия: C, Файл опубликован: 12 янв 2007
SN74AUC2G126DCTRSN74AUC2G126DCUR
Доступность образцов у производителяДаДа
N12
Pin88
Package TypeDCTDCU
Industry STD TermSSOPVSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаRU26Q
Width (мм)2.82
Length (мм)2.952.3
Thickness (мм)1.29.85
Pitch (мм).65.5
Max Height (мм)1.3.9
Parameters / ModelsSN74AUC2G126DCTR
SN74AUC2G126DCTR
SN74AUC2G126DCUR
SN74AUC2G126DCUR
3-State OutputYesYes
Bits22
F @ Nom Voltage(Max), Mhz250250
Gate TypeBUFFERBUFFER
ICC @ Nom Voltage(Max), мА0.010.01
LogicTrueTrue
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА9/-99/-9
Package GroupSM8VSSOP
Package Size: mm2:W x L, PKG8SM8: 12 mm2: 4 x 2.95(SM8)8VSSOP: 6 mm2: 3.1 x 2(VSSOP)
RatingCatalogCatalog
Schmitt TriggerNoNo
Special FeaturesIOFF,low power consumption,low tpd,3-stateIOFF,low power consumption,low tpd,3-state
Sub-FamilyNon-Inverting Buffer/DriverNon-Inverting Buffer/Driver
Technology FamilyAUCAUC
VCC(Max), В2.72.7
VCC(Min), В0.80.8
Voltage(Nom), В0.8,1.2,1.5,1.8,2.50.8,1.2,1.5,1.8,2.5
tpd @ Nom Voltage(Max), нс5.4,3.5,2.3,1.9,1.45.4,3.5,2.3,1.9,1.4
RoHSСовместимСовместим
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUC2G126 (2)
  • Semiconductors> Logic> Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC2G126
