Datasheet Texas Instruments SN74AUCH245 — Даташит
СерияSN74AUCH245
Восьмеричный шинный трансивер с выходами с 3 состояниями
SN74AUCH245 datasheet
PDF, 826 Кб, Файл опубликован: 31 дек 2002
SN74AUCH245RGYR
Статус продуктаВ производстве
SN74AUCH245RGYR
N1
Pin20
Package TypeRGY
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаMT245
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Parameters / ModelsSN74AUCH245RGYR
SN74AUCH245RGYR
Bits8
F @ Nom Voltage(Max), Mhz250
ICC @ Nom Voltage(Max), мА0.02
Рабочий диапазон температур, Cот -40 до 85
Output Drive (IOL/IOH)(Max), мА-9/9
Package GroupVQFN
Package Size: mm2:W x L, PKG20VQFN: 16 mm2: 3.5 x 4.5(VQFN)
Schmitt TriggerNo
Technology FamilyAUC
VCC(Max), В2.7
VCC(Min), В0.8
Voltage(Nom), В0.8,1.2,1.5,1.8,2.5
tpd @ Nom Voltage(Max), нс5,3.3,2,1.7,1.4
SN74AUCH245RGYR
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUCH245 (1)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74AUCH245
