Datasheet Texas Instruments SN74AVC16835DGVR — Даташит
СерияSN74AVC16835
МодельSN74AVC16835DGVR
18-битный универсальный драйвер шины с выходами с 3 состояниями 56-TVSOP от -40 до 85
18-Bit Universal Bus Driver With 3-State Outputs datasheet
PDF, 423 Кб, Версия: J, Файл опубликован: 12 фев 2002
Pin56
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаCVA835
Width (мм)4.4
Length (мм)11.3
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
F @ Nom Voltage(Max)150 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Package GroupTVSOP
Package Size: mm2:W x L56TVSOP: 72 mm2: 6.4 x 11.3(TVSOP) PKG
Schmitt TriggerNo
Technology FamilyAVC
VCC(Max)3.6 В
VCC(Min)1.4 В
Voltage(Nom)1.8,2.5,3.3 В
tpd @ Nom Voltage(Max)7.2,4.7,3.8 нс
  • Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
    Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i
  • AVC Logic Family Technology and Applications (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
    Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control (
  • Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)
    PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74AVC16835 (2)
  • Semiconductors > Logic > Universal Bus Function > Universal Bus Driver (UBD)
На английском языке: Datasheet Texas Instruments SN74AVC16835DGVR
