Datasheet Texas Instruments SN74AVC16835DGGR — Даташит
СерияSN74AVC16835
МодельSN74AVC16835DGGR
18-битный универсальный драйвер шины с выходами с 3 состояниями 56-TSSOP от -40 до 85
18-Bit Universal Bus Driver With 3-State Outputs datasheet
PDF, 423 Кб, Версия: J, Файл опубликован: 12 фев 2002
26 предложений от 17 поставщиков
Микросхема Логический контроллер, 18Bit Universal Bus Driver With 3-State Outputs 56-TSSOP -40℃ to 85℃
SN74AVC16835DGGR
245 ₽
SN74AVC16835DGGR
от 260 ₽
SN74AVC16835DGGR
Рутоника
SN74AVC16835DGGR
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаAVC16835
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Approx. Price (US$)1.29 | 1ku
F @ Nom Voltage(Max)(Mhz)150
ICC @ Nom Voltage(Max)(mA)0.04
Operating Temperature Range(C)-40 to 85
Package GroupTSSOP
Package Size: mm2:W x L (PKG)56TSSOP: 113 mm2: 8.1 x 14(TSSOP)
Schmitt TriggerNo
Technology FamilyAVC
VCC(Max)(V)3.6
VCC(Min)(V)1.4
Voltage(Nom)(V)1.8
2.5
3.3
tpd @ Nom Voltage(Max)(ns)7.2
4.7
3.8
  • Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
    Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i
  • AVC Logic Family Technology and Applications (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
    Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control (
  • Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)
    PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74AVC16835 (2)
  • Semiconductors > Logic > Universal Bus Function > Universal Bus Driver (UBD)
На английском языке: Datasheet Texas Instruments SN74AVC16835DGGR
