Datasheet Texas Instruments SN74CBT34X245 — Даташит
СерияSN74CBT34X245
32-битный коммутатор шины на полевом транзисторе
32-Bit FET Bus Switch datasheet
PDF, 290 Кб, Версия: C, Файл опубликован: 30 апр 2001
SN74CBT34X245DBBR
Статус продуктаВ производстве
SN74CBT34X245DBBR
N1
Pin80
Package TypeDBB
Industry STD TermTSSOP
Package QTY2000
МаркировкаCBT34X245
Width (мм)6.1
Length (мм)17
Thickness (мм)1.15
Pitch (мм).4
Max Height (мм)1.2
Parameters / ModelsSN74CBT34X245DBBR
SN74CBT34X245DBBR
Additional FeaturesPowered off protection
Полоса частот, МГц200
Configuration1:1 SPST
ESD Charged Device Model, kV1
ESD HBM, kV2
Input/Ouput Voltage(Max), В5.5
Input/Output Continuous Current(Max), мА128
Input/Output OFF-state Capacitance(Typ), пФ5.5
Количество каналов32
OFF-state leakage current(Max), мкА5
ON-state leakage current(Max), мкА5
Рабочий диапазон температур, Cот -40 до 85
Package GroupTSSOP
Package Size: mm2:W x L, PKG80TSSOP: 138 mm2: 8.1 x 17(TSSOP)
Ron(Max), Ohms17
Ron(Typ), Ohms5
Supply Current(Max), uA3
Supply Range, Max5.5
VIH(Min), В2
VIL(Max), В0.8
Vdd(Max), В5.5
Vdd(Min), В4
Vss(Max), ВN/A
Vss(Min), ВN/A
SN74CBT34X245DBBR
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
Серия: SN74CBT34X245 (1)
  • Semiconductors> Switches and Multiplexers> Analog Switches/Muxes
На английском языке: Datasheet Texas Instruments SN74CBT34X245
