Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74CBTLV3257-EP — Даташит
СерияSN74CBTLV3257-EP
Усовершенствованный низковольтный 4-битный мультиплексор/демультиплексор на полевых транзисторах «1 из 2»
Low-Voltage 4-Bit 1-of-2 FET Multiplexer/Demultiplexer datasheet
PDF, 489 Кб, Файл опубликован: 29 май 2008
CCBTLV3257MPWREPV62/08615-01XE
N12
Pin1616
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаCL257EPCL257EP
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Parameters / ModelsCCBTLV3257MPWREP
CCBTLV3257MPWREP
V62/08615-01XE
V62/08615-01XE
Additional FeaturesIOFFIOFF
Bandwidth(Max), МГц200200
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG16TSSOP: 32 mm2: 6.4 x 5(TSSOP)16TSSOP: 32 mm2: 6.4 x 5(TSSOP)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Ron(Max), Ohms77
Ron(Typ), Ohms55
Schmitt TriggerNoNo
Technology FamilyCBTLVCBTLV
VCC(Max), В3.63.6
VCC(Min), В2.32.3
RoHSСовместимСовместим
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: SN74CBTLV3257-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Switches and Multiplexer> Multiplexers/Demultiplexers (Mux/Demux)
На английском языке: Datasheet Texas Instruments SN74CBTLV3257-EP
Публикации по теме
