Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74FB1653PCA — Даташит
СерияSN74FB1653
МодельSN74FB1653PCA
17-битные универсальные приемопередатчики хранения данных LVTTL/BTL с буферизованными линиями тактовой частоты 100-HLQFP от 0 до 70
SN74FB1653 datasheet
PDF, 262 Кб, Версия: H, Файл опубликован: 10 мар 2004
Pin100
Package TypePCA
Industry STD TermHLQFP
JEDEC CodeS-PQFP-G
Package QTY90
CarrierJEDEC TRAY (10+1)
МаркировкаFB1653
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
Bits17
F @ Nom Voltage(Max)90 Mhz
ICC @ Nom Voltage(Max)140 мА
Output Drive (IOL/IOH)(Max)100/-32 мА
Package GroupHLQFP
Package Size: mm2:W x L100HLQFP: 256 mm2: 16 x 16(HLQFP) PKG
Schmitt TriggerNo
Technology FamilyFB
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)15.4 нс
  • Next-Generation BTL/Futurebus Transceivers Allow Single-Sided SMT Manufacturing (Rev. C)
    PDF, 65 Кб, Версия: C, Файл опубликован: 1 мар 1997
    BTL- and Futurebus-compatible transceivers and switching level meet the requirements of today?s high-speed data-communications and provide significant performance advantages over conventional backplane implementations. This document discusses the current and next generation of BTL/Futurebus Transceivers and the design trade-offs required when using these devices.
  • GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)
    PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
    GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided.
Серия: SN74FB1653 (1)
  • SN74FB1653PCA
  • Semiconductors > Logic > Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
На английском языке: Datasheet Texas Instruments SN74FB1653PCA
