Datasheet Texas Instruments SN74FB1653 — Даташит
СерияSN74FB1653
17-битные универсальные приемопередатчики памяти LVTTL/BTL с буферизованными линиями тактовой частоты
SN74FB1653 datasheet
PDF, 262 Кб, Версия: H, Файл опубликован: 10 мар 2004
SN74FB1653PCA
Статус продуктаВ производстве
SN74FB1653PCA
N1
Pin100
Package TypePCA
Industry STD TermHLQFP
JEDEC CodeS-PQFP-G
Package QTY90
CarrierJEDEC TRAY (10+1)
МаркировкаFB1653
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
Parameters / ModelsSN74FB1653PCA
SN74FB1653PCA
Bits17
F @ Nom Voltage(Max), Mhz90
ICC @ Nom Voltage(Max), мА140
Рабочий диапазон температур, Cот 0 до 70
Output Drive (IOL/IOH)(Max), мА100/-32
Package GroupHLQFP
Package Size: mm2:W x L, PKG100HLQFP: 256 mm2: 16 x 16(HLQFP)
Schmitt TriggerNo
Technology FamilyFB
VCC(Max), В5.5
VCC(Min), В4.5
Voltage(Nom), В5
tpd @ Nom Voltage(Max), нс15.4
SN74FB1653PCA
  • Next-Generation BTL/Futurebus Transceivers Allow Single-Sided SMT Manufacturing (Rev. C)
    PDF, 65 Кб, Версия: C, Файл опубликован: 1 мар 1997
    BTL- and Futurebus-compatible transceivers and switching level meet the requirements of today?s high-speed data-communications and provide significant performance advantages over conventional backplane implementations. This document discusses the current and next generation of BTL/Futurebus Transceivers and the design trade-offs required when using these devices.
  • GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)
    PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
    GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided.
Серия: SN74FB1653 (1)
  • Semiconductors> Logic> Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
На английском языке: Datasheet Texas Instruments SN74FB1653
