Datasheet Texas Instruments SN74FB2031 — Даташит
СерияSN74FB2031
9-битный TTL/BTL адрес/приемопередатчик данных
9-Bit TTL/BTL Address/Data Transceiver datasheet
PDF, 695 Кб, Версия: N, Файл опубликован: 22 июн 2001
SN74FB2031RCG3SN74FB2031RCRG3
N12
Pin5252
Package TypeRCRC
Industry STD TermQFPQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY96500
CarrierJEDEC TRAY (5+1)LARGE T&R
МаркировкаFB2031FB2031
Width (мм)1010
Length (мм)1010
Thickness (мм)22
Pitch (мм).65.65
Max Height (мм)2.452.45
Parameters / ModelsSN74FB2031RCG3SN74FB2031RCRG3
SN74FB2031RCRG3
Approx. Price (US$)24.00 | 1ku
Bits9
Bits(#)9
F @ Nom Voltage(Max), Mhz150
F @ Nom Voltage(Max)(Mhz)150
ICC @ Nom Voltage(Max), мА78
ICC @ Nom Voltage(Max)(mA)78
Рабочий диапазон температур, Cот 0 до 70
Output Drive (IOL/IOH)(Max), мА100/-32
Output Drive (IOL/IOH)(Max)(mA)100/-32
Package GroupQFPQFP
Package Size: mm2:W x L, PKG52QFP: 174 mm2: 13.2 x 13.2(QFP)
Package Size: mm2:W x L (PKG)52QFP: 174 mm2: 13.2 x 13.2(QFP)
RatingCatalogCatalog
Schmitt TriggerNoNo
Technology FamilyFBFB
VCC(Max), В5.5
VCC(Max)(V)5.5
VCC(Min), В4.5
VCC(Min)(V)4.5
Voltage(Nom), В5
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max), нс7.8
tpd @ Nom Voltage(Max)(ns)7.8
RoHSСовместимСовместим
  • Next-Generation BTL/Futurebus Transceivers Allow Single-Sided SMT Manufacturing (Rev. C)
    PDF, 65 Кб, Версия: C, Файл опубликован: 1 мар 1997
    BTL- and Futurebus-compatible transceivers and switching level meet the requirements of today?s high-speed data-communications and provide significant performance advantages over conventional backplane implementations. This document discusses the current and next generation of BTL/Futurebus Transceivers and the design trade-offs required when using these devices.
  • GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)
    PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
    GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided.
Серия: SN74FB2031 (2)
  • Semiconductors> Logic> Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
На английском языке: Datasheet Texas Instruments SN74FB2031
