Datasheet Texas Instruments SN74FB2033A — Даташит
СерияSN74FB2033A
8-битный регистровый трансивер TTL/BTL
8-Bit TTL/BTL Registered Transceiver datasheet
PDF, 740 Кб, Версия: M, Файл опубликован: 10 сен 2001
SN74FB2033ARCRG3
Статус продуктаВ производстве
SN74FB2033ARCRG3
N1
Pin52
Package TypeRC
Industry STD TermQFP
JEDEC CodeS-PQFP-G
Package QTY500
МаркировкаFB2033A
Width (мм)10
Length (мм)10
Thickness (мм)2
Max Height (мм)2.45
Parameters / ModelsSN74FB2033ARCRG3
SN74FB2033ARCRG3
Bits8
F @ Nom Voltage(Max), Mhz150
ICC @ Nom Voltage(Max), мА70
Рабочий диапазон температур, Cот 0 до 70
Output Drive (IOL/IOH)(Max), мА100/-32
Package GroupQFP
Package Size: mm2:W x L, PKG52QFP: 174 mm2: 13.2 x 13.2(QFP)
Schmitt TriggerNo
Technology FamilyFB
VCC(Max), В5.25
VCC(Min), В4.75
Voltage(Nom), В5
tpd @ Nom Voltage(Max), нс8
SN74FB2033ARCRG3
  • Next-Generation BTL/Futurebus Transceivers Allow Single-Sided SMT Manufacturing (Rev. C)
    PDF, 65 Кб, Версия: C, Файл опубликован: 1 мар 1997
    BTL- and Futurebus-compatible transceivers and switching level meet the requirements of today?s high-speed data-communications and provide significant performance advantages over conventional backplane implementations. This document discusses the current and next generation of BTL/Futurebus Transceivers and the design trade-offs required when using these devices.
  • GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)
    PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
    GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided.
Серия: SN74FB2033A (1)
  • Semiconductors> Logic> Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
На английском языке: Datasheet Texas Instruments SN74FB2033A
