Datasheet Texas Instruments SN74FB2040RCG3 — Даташит
| Серия | SN74FB2040 |
| Модель | SN74FB2040RCG3 |
8-битные трансиверы TTL/BTL 52-QFP от 0 до 70
8-Bit TTL/BTL Transceiver datasheet
PDF, 138 Кб, Версия: N, Файл опубликован: 7 мар 2002
Купить SN74FB2040RCG3 на РадиоЛоцман.Цены — от 1 045 до 2 976 ₽16 предложений от 16 поставщиков Микросхема Логический контроллер, Bus XCVR Single 8CH 3-ST/Open Collector 52Pin PQFP Tray | |||
| SN74FB2040RCG3 Texas Instruments | 1 219 ₽ | ||
| SN74FB2040RCG3 Texas Instruments | 2 764 ₽ | ||
| SN74FB2040RCG3 Texas Instruments | по запросу | ||
| Pin | 52 |
| Package Type | RC |
| Industry STD Term | QFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 96 |
| Carrier | JEDEC TRAY (5+1) |
| Маркировка | FB2040 |
| Width (мм) | 10 |
| Length (мм) | 10 |
| Thickness (мм) | 2 |
| Pitch (мм) | .65 |
| Max Height (мм) | 2.45 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 150 Mhz |
| ICC @ Nom Voltage(Max) | 70 мА |
| Рабочий диапазон температур | от 0 до 70 C |
| Output Drive (IOL/IOH)(Max) | 100/-32 мА |
| Package Group | QFP |
| Package Size: mm2:W x L | 52QFP: 174 mm2: 13.2 x 13.2(QFP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | FB |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| Voltage(Nom) | 5 В |
| tpd @ Nom Voltage(Max) | 8.2 нс |
- Next-Generation BTL/Futurebus Transceivers Allow Single-Sided SMT Manufacturing (Rev. C)PDF, 65 Кб, Версия: C, Файл опубликован: 1 мар 1997
BTL- and Futurebus-compatible transceivers and switching level meet the requirements of today?s high-speed data-communications and provide significant performance advantages over conventional backplane implementations. This document discusses the current and next generation of BTL/Futurebus Transceivers and the design trade-offs required when using these devices. - GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided. - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74FB2040 (1)
- SN74FB2040RCG3
- Semiconductors > Logic > Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
