Datasheet Texas Instruments SN74GTL16622A — Даташит
СерияSN74GTL16622A
18-битный трансивер шины LVTTL-GTL/GTL+
18-Bit LVTTL-to-GTL/GTL+ Bus Transceiver datasheet
PDF, 456 Кб, Версия: F, Файл опубликован: 6 авг 2001
SN74GTL16622ADGGR
Статус продуктаВ производстве
SN74GTL16622ADGGR
N1
Pin64
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаGTL16622A
Width (мм)6.1
Length (мм)17
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Parameters / ModelsSN74GTL16622ADGGR
SN74GTL16622ADGGR
Bits18
F @ Nom Voltage(Max), Mhz200
ICC @ Nom Voltage(Max), мА60
Рабочий диапазон температур, Cот -40 до 85
Output Drive (IOL/IOH)(Max), мА50
Package GroupTSSOP
Package Size: mm2:W x L, PKG64TSSOP: 138 mm2: 8.1 x 17(TSSOP)
Schmitt TriggerNo
Technology FamilyGTL
VCC(Max), В3.45
VCC(Min), В3.15
Voltage(Nom), В3.3
tpd @ Nom Voltage(Max), нс5.7
SN74GTL16622ADGGR
  • GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)
    PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
    GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided.
Серия: SN74GTL16622A (1)
  • Semiconductors> Logic> Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
На английском языке: Datasheet Texas Instruments SN74GTL16622A
