Datasheet Texas Instruments SN74GTL2003RKSR — Даташит
Серия | SN74GTL2003 |
Модель | SN74GTL2003RKSR |
8-битный двунаправленный преобразователь низкого напряжения 20-VQFN от -40 до 85
SN74GTL2003 8-Bit Bidirectional Low-Voltage Translator datasheet
PDF, 994 Кб, Версия: C, Файл опубликован: 30 авг 2016
Pin | 20 |
Package Type | RKS |
Industry STD Term | VQFN |
JEDEC Code | R-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | GK2003 |
Width (мм) | 2.5 |
Length (мм) | 4.5 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Bits | 8 |
F @ Nom Voltage(Max) | 95 Mhz |
ICC @ Nom Voltage(Max) | 0.001 мА |
Output Drive (IOL/IOH)(Max) | 64 мА |
Package Group | VQFN |
Package Size: mm2:W x L | 20VQFN: 11 mm2: 2.5 x 4.5(VQFN) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | GTL |
VCC(Max) | 5.5 В |
VCC(Min) | 1 В |
Voltage(Nom) | 1,1.8,2.5,3.3,5 В |
tpd @ Nom Voltage(Max) | 5.5,0.25 нс |
- GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided. - VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74GTL2003 (3)
- SN74GTL2003PW SN74GTL2003PWR SN74GTL2003RKSR
- Semiconductors > Logic > Universal Bus Function > Universal Bus Transceiver (UBT)
