Datasheet Texas Instruments SN74GTL2010PWR — Даташит
| Серия | SN74GTL2010 |
| Модель | SN74GTL2010PWR |
10-битное ограничение напряжения 24-TSSOP от -40 до 85
Купить SN74GTL2010PWR на РадиоЛоцман.Цены — от 27 до 333 ₽34 предложений от 16 поставщиков Микросхема Преобразователь напряжения и электроуровня, 10Bit Voltage Clamp 24-TSSOP -40℃ to 85℃3 | |||
| SN74GTL2010PWR Texas Instruments | 51 ₽ | ||
| SN74GTL2010PWR Texas Instruments | 61 ₽ | ||
| SN74GTL2010PWR Texas Instruments | от 323 ₽ | ||
| SN74GTL2010PWR Texas Instruments | от 333 ₽ | ||
| Pin | 24 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | GK2010 |
| Width (мм) | 4.4 |
| Length (мм) | 7.8 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 10 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 3 мА |
| Output Drive (IOL/IOH)(Max) | 64 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | GTL |
| VCC(Max) | 5.5 В |
| VCC(Min) | 1 В |
| Voltage(Nom) | 5 В |
| tpd @ Nom Voltage(Max) | 0.25 нс |
- GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided. - VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74GTL2010 (2)
- SN74GTL2010PW SN74GTL2010PWR
- Semiconductors > Logic > Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
