Datasheet Texas Instruments SN74GTL2107PWR — Даташит
| Серия | SN74GTL2107 |
| Модель | SN74GTL2107PWR |
12-битный преобразователь GTL-/GTL/GTL+ в LVTTL 28-TSSOP от -40 до 85
Купить SN74GTL2107PWR на РадиоЛоцман.Цены — от 31 до 327 ₽38 предложений от 17 поставщиков IC TRNSLTR UNIDIR 28TSSOP. Mixed Signal Translator Unidirectional 1 Circuit 12 Channel 28-TSSOP. Logic - Translators, Level Shifters | |||
| SN74GTL2107PWR Texas Instruments | от 110 ₽ | ||
| SN74GTL2107PWR Texas Instruments | от 279 ₽ | ||
| SN74GTL2107PWR Texas Instruments | по запросу | ||
| Pin | 28 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | GK2107 |
| Width (мм) | 4.4 |
| Length (мм) | 9.7 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 12 |
| F @ Nom Voltage(Max) | 95 Mhz |
| ICC @ Nom Voltage(Max) | 12 мА |
| Output Drive (IOL/IOH)(Max) | -16/16 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | GTL |
| VCC(Max) | 3.6 В |
| VCC(Min) | 3 В |
| Voltage(Nom) | 3.3 В |
| tpd @ Nom Voltage(Max) | 10 нс |
- GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided. - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74GTL2107 (4)
- SN74GTL2107PW SN74GTL2107PWG4 SN74GTL2107PWR SN74GTL2107PWRG4
- Semiconductors > Logic > Universal Bus Function > Universal Bus Transceiver (UBT)
