Datasheet Texas Instruments SN74GTL3004DCKR — Даташит
| Серия | SN74GTL3004 |
| Модель | SN74GTL3004DCKR |
Выбираемое опорное напряжение GTL 6-SC70 от -40 до 85
Selectable GTL Voltage Reference datasheet
PDF, 368 Кб, Версия: A, Файл опубликован: 1 апр 2008
Купить SN74GTL3004DCKR на РадиоЛоцман.Цены — от 6.55 до 49 ₽40 предложений от 14 поставщиков IC TRNSLTR UNIDIRECTIONAL SC70-6. Voltage Level Translator Unidirectional 1 Circuit 1 Channel SC-70-6. Logic - Translators, Level Shifters | |||
| SN74GTL3004DCKR Texas Instruments | 12 ₽ | ||
| SN74GTL3004DCKR Texas Instruments | 15 ₽ | ||
| SN74GTL3004DCKR Texas Instruments | от 48 ₽ | ||
| SN74GTL3004DCKR | по запросу | ||
| Pin | 6 |
| Package Type | DCK |
| Industry STD Term | SOT-SC70 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | 2TK |
| Width (мм) | 1.25 |
| Length (мм) | 2 |
| Thickness (мм) | .9 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.1 |
| Mechanical Data | Скачать |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.085 мА |
| Package Group | SC70 |
| Package Size: mm2:W x L | 6SC70: 4 mm2: 2.1 x 2(SC70) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | GTL |
| VCC(Max) | 3.6 В |
| VCC(Min) | 3 В |
| Voltage(Nom) | 3.3 В |
- GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided. - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74GTL3004 (1)
- SN74GTL3004DCKR
- Semiconductors > Logic > Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
