Datasheet Texas Instruments SN74GTLP22033DGGR — Даташит
| Серия | SN74GTLP22033 |
| Модель | SN74GTLP22033DGGR |
8-битный регистровый приемопередатчик LVTTL-GTLP с регулируемой частотой фронта, разделенным портом LVTTL и каналом обратной связи 48-TSSOP от -40 до 85
8-Bit LVTTL-to-GTLP Adj.-Edge-Rate Regstd.Xcvr W/ Split LVTTL Port&Feedbk Path datasheet
PDF, 805 Кб, Версия: C, Файл опубликован: 4 сен 2001
Купить SN74GTLP22033DGGR на РадиоЛоцман.Цены — от 121 до 876 ₽21 предложений от 17 поставщиков Микросхема Логический чип, 8Bit LVTTL-GTLP Adjustable-Edge-Rate Registered Transceiver with Split LVTTL Port and Feedback Path 48-TSSOP -40℃ to 85℃ | |||
| SN74GTLP22033DGGR Texas Instruments | 351 ₽ | ||
| SN74GTLP22033DGGR Rochester Electronics | 400 ₽ | ||
| SN74GTLP22033DGGR Texas Instruments | от 874 ₽ | ||
| SN74GTLP22033DGGR Texas Instruments | по запросу | ||
| Pin | 48 |
| Package Type | DGG |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | GTLP22033 |
| Width (мм) | 6.1 |
| Length (мм) | 12.5 |
| Thickness (мм) | 1.15 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 175 Mhz |
| ICC @ Nom Voltage(Max) | 40 мА |
| Output Drive (IOL/IOH)(Max) | 100 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | GTLP |
| VCC(Max) | 3.45 В |
| VCC(Min) | 3.15 В |
| Voltage(Nom) | 3.3 В |
| tpd @ Nom Voltage(Max) | 8.8 нс |
- Texas Instruments GTLP Frequently Asked QuestionsPDF, 496 Кб, Файл опубликован: 1 янв 2001
Using a question-and-answer format, advantages of TI?s GTLP devices, particularly for backplane applications, are presented, as well as differences between GTLP and GTL/LVDS devices. Applicable topics include data throughput rates, synchronous clocks, price and alternative sources, bus transceivers, live insertion, power consumption, backplane termination, voltage translation, IBIS and HSPICE mode - Logic in Live-Insertion Applications With a Focus on GTLPPDF, 493 Кб, Файл опубликован: 14 янв 2002
Live-insertion capability is an essential part of today?s high-speed data systems because those systems are expected to run continuously without being powered down. This application report delves into the cause and prevention of live-insertion and nanosecond-discontinuity effects, using both simulation and actual test measurements from a specially built GTLP EVM. Hypothetical cases for precharge c - Achieving Maximum Speed on Parallel Buses With Gunning Transceiver Logic (GTLP)PDF, 585 Кб, Файл опубликован: 5 апр 2001
This application report compares two approaches for synchronous bus-system designs. The focus of the report is the comparison of a system using central-synchronous system clock (CSSC) with a system operated with a source-synchronous system clock (SSSC).The basic characteristics of lines, key factors that influence the bus line delay, and the impedance of bus lines are described.The theoretical - Fast GTLP Backplanes With the GTLPH1655 (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 19 сен 2000
This revision of the Fast GTL Backplanes With the GTL1655 application report addresses improvements, such as the improved OECE circuitry and implementation of theTexas Instruments TI-OPCE circuitry, that have been incorporated in the GTLPH1655 device. These improvements significantly improve signal integrity in distributed loads.This application report describes the physical principles of fast - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74GTLP22033 (1)
- SN74GTLP22033DGGR
- Semiconductors > Logic > Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
