Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74GTLP817PW — Даташит
СерияSN74GTLP817
МодельSN74GTLP817PW
GTLP-to-LVTTL Драйвер разветвления от 1 до 6 24-TSSOP От -40 до 85
GTLP-to-LVTTL 1-to-6 Fanout Driver datasheet
PDF, 190 Кб, Версия: E, Файл опубликован: 14 авг 2001
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY60
МаркировкаGT817
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Bits6
F @ Nom Voltage(Max)175 Mhz
ICC @ Nom Voltage(Max)10 мА
Output Drive (IOL/IOH)(Max)50 мА
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyGTLP
VCC(Max)3.45 В
VCC(Min)3.15 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)6 нс
  • Texas Instruments GTLP Frequently Asked Questions
    PDF, 496 Кб, Файл опубликован: 1 янв 2001
    Using a question-and-answer format, advantages of TI?s GTLP devices, particularly for backplane applications, are presented, as well as differences between GTLP and GTL/LVDS devices. Applicable topics include data throughput rates, synchronous clocks, price and alternative sources, bus transceivers, live insertion, power consumption, backplane termination, voltage translation, IBIS and HSPICE mode
  • Logic in Live-Insertion Applications With a Focus on GTLP
    PDF, 493 Кб, Файл опубликован: 14 янв 2002
    Live-insertion capability is an essential part of today?s high-speed data systems because those systems are expected to run continuously without being powered down. This application report delves into the cause and prevention of live-insertion and nanosecond-discontinuity effects, using both simulation and actual test measurements from a specially built GTLP EVM. Hypothetical cases for precharge c
  • Achieving Maximum Speed on Parallel Buses With Gunning Transceiver Logic (GTLP)
    PDF, 585 Кб, Файл опубликован: 5 апр 2001
    This application report compares two approaches for synchronous bus-system designs. The focus of the report is the comparison of a system using central-synchronous system clock (CSSC) with a system operated with a source-synchronous system clock (SSSC).The basic characteristics of lines, key factors that influence the bus line delay, and the impedance of bus lines are described.The theoretical
  • Fast GTLP Backplanes With the GTLPH1655 (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 19 сен 2000
    This revision of the Fast GTL Backplanes With the GTL1655 application report addresses improvements, such as the improved OECE circuitry and implementation of theTexas Instruments TI-OPCE circuitry, that have been incorporated in the GTLPH1655 device. These improvements significantly improve signal integrity in distributed loads.This application report describes the physical principles of fast
Серия: SN74GTLP817 (1)
  • SN74GTLP817PW
  • Semiconductors > Logic > Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
На английском языке: Datasheet Texas Instruments SN74GTLP817PW
