Datasheet Texas Instruments SN74GTLPH306DW — Даташит
Серия | SN74GTLPH306 |
Модель | SN74GTLPH306DW |
8-битный трансивер шины LVTTL-GTLP 24-SOIC от -40 до 85
8-Bit LVTTL-to-GTL+ Bus Transceiver datasheet
PDF, 583 Кб, Версия: E, Файл опубликован: 14 авг 2001
Pin | 24 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | GTLPH306 |
Width (мм) | 7.5 |
Length (мм) | 15.4 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Bits | 8 |
F @ Nom Voltage(Max) | 175 Mhz |
ICC @ Nom Voltage(Max) | 20 мА |
Output Drive (IOL/IOH)(Max) | 50 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 24SOIC: 160 mm2: 10.3 x 15.5(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | GTLP |
VCC(Max) | 3.45 В |
VCC(Min) | 3.15 В |
Voltage(Nom) | 3.3 В |
tpd @ Nom Voltage(Max) | 7.5 нс |
- Texas Instruments GTLP Frequently Asked QuestionsPDF, 496 Кб, Файл опубликован: 1 янв 2001
Using a question-and-answer format, advantages of TI?s GTLP devices, particularly for backplane applications, are presented, as well as differences between GTLP and GTL/LVDS devices. Applicable topics include data throughput rates, synchronous clocks, price and alternative sources, bus transceivers, live insertion, power consumption, backplane termination, voltage translation, IBIS and HSPICE mode - Logic in Live-Insertion Applications With a Focus on GTLPPDF, 493 Кб, Файл опубликован: 14 янв 2002
Live-insertion capability is an essential part of today?s high-speed data systems because those systems are expected to run continuously without being powered down. This application report delves into the cause and prevention of live-insertion and nanosecond-discontinuity effects, using both simulation and actual test measurements from a specially built GTLP EVM. Hypothetical cases for precharge c - Achieving Maximum Speed on Parallel Buses With Gunning Transceiver Logic (GTLP)PDF, 585 Кб, Файл опубликован: 5 апр 2001
This application report compares two approaches for synchronous bus-system designs. The focus of the report is the comparison of a system using central-synchronous system clock (CSSC) with a system operated with a source-synchronous system clock (SSSC).The basic characteristics of lines, key factors that influence the bus line delay, and the impedance of bus lines are described.The theoretical - Fast GTLP Backplanes With the GTLPH1655 (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 19 сен 2000
This revision of the Fast GTL Backplanes With the GTL1655 application report addresses improvements, such as the improved OECE circuitry and implementation of theTexas Instruments TI-OPCE circuitry, that have been incorporated in the GTLPH1655 device. These improvements significantly improve signal integrity in distributed loads.This application report describes the physical principles of fast - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74GTLPH306 (6)
- 74GTLPH306DGVRE4 SN74GTLPH306DGVR SN74GTLPH306DW SN74GTLPH306DWR SN74GTLPH306PW SN74GTLPH306PWR
- Semiconductors > Logic > Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
