Datasheet Texas Instruments SN74GTLPH32945KR — Даташит
| Серия | SN74GTLPH32945 |
| Модель | SN74GTLPH32945KR |
32-битный трансивер шины LVTTL-GTLP 96-LFBGA от -40 до 85
32-Bit LVTTL-to-GTLP Bus Transceiver datasheet
PDF, 739 Кб, Версия: C, Файл опубликован: 28 ноя 2001
Купить SN74GTLPH32945KR на РадиоЛоцман.Цены — от 63 до 718 ₽23 предложений от 17 поставщиков IC TRNSLTR BIDIRECTIONAL 96LFBGA. Mixed Signal Translator Bidirectional 4 Circuit 8 Channel 96-LFBGA (13.5x5.5). Logic - Translators, Level Shifters | |||
| SN74GTLPH32945KR Texas Instruments | 63 ₽ | ||
| SN74GTLPH32945KR Texas Instruments | 296 ₽ | ||
| SN74GTLPH32945KR Texas Instruments | по запросу | ||
| Статус продукта | NRND (Не рекомендуется для новых разработок) |
| Pin | 96 |
| Package Type | GKE |
| Industry STD Term | BGA MICROSTAR |
| JEDEC Code | R-PBGA-N |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | GM945 |
| Width (мм) | 5.5 |
| Length (мм) | 13.5 |
| Thickness (мм) | .9 |
| Pitch (мм) | .8 |
| Max Height (мм) | 1.4 |
| Mechanical Data | Скачать |
| RoHS | See ti.com |
- Texas Instruments GTLP Frequently Asked QuestionsPDF, 496 Кб, Файл опубликован: 1 янв 2001
Using a question-and-answer format, advantages of TI?s GTLP devices, particularly for backplane applications, are presented, as well as differences between GTLP and GTL/LVDS devices. Applicable topics include data throughput rates, synchronous clocks, price and alternative sources, bus transceivers, live insertion, power consumption, backplane termination, voltage translation, IBIS and HSPICE mode - Logic in Live-Insertion Applications With a Focus on GTLPPDF, 493 Кб, Файл опубликован: 14 янв 2002
Live-insertion capability is an essential part of today?s high-speed data systems because those systems are expected to run continuously without being powered down. This application report delves into the cause and prevention of live-insertion and nanosecond-discontinuity effects, using both simulation and actual test measurements from a specially built GTLP EVM. Hypothetical cases for precharge c - Achieving Maximum Speed on Parallel Buses With Gunning Transceiver Logic (GTLP)PDF, 585 Кб, Файл опубликован: 5 апр 2001
This application report compares two approaches for synchronous bus-system designs. The focus of the report is the comparison of a system using central-synchronous system clock (CSSC) with a system operated with a source-synchronous system clock (SSSC).The basic characteristics of lines, key factors that influence the bus line delay, and the impedance of bus lines are described.The theoretical - Fast GTLP Backplanes With the GTLPH1655 (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 19 сен 2000
This revision of the Fast GTL Backplanes With the GTL1655 application report addresses improvements, such as the improved OECE circuitry and implementation of theTexas Instruments TI-OPCE circuitry, that have been incorporated in the GTLPH1655 device. These improvements significantly improve signal integrity in distributed loads.This application report describes the physical principles of fast - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74GTLPH32945 (1)
- SN74GTLPH32945KR
- Semiconductors > Logic > Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
