Datasheet Texas Instruments SN74LS00 — Даташит
СерияSN74LS00
Четырехвходовые логические элементы положительного И-НЕ с 2 входами
SNx400, SNx4LS00, and SNx4S00 Quadruple 2-Input Positive-NAND Gates datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 19 май 2017
SN74LS00DSN74LS00DBLESN74LS00DBRSN74LS00DG4SN74LS00DRSN74LS00DRE4SN74LS00JSN74LS00NSN74LS00NE4SN74LS00NSRSN74LS00NSRG4SN74LS00PSRSN74LS00PSRG4
Статус продуктаВ производствеСнят с производстваВ производствеВ производствеВ производствеВ производствеСнят с производстваВ производствеВ производствеВ производствеВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНетНетНетНетНетНетДаНетНетНетНет
N12345678910111213
Pin141414141414141414141488
Package TypeDDBDBDDDJNNNSNSPSPS
Industry STD TermSOICSSOPSSOPSOICSOICSOICCDIPPDIPPDIPSOPSOPSOPSOP
JEDEC CodeR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-GDIP-TR-PDIP-TR-PDIP-TR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-G
Package QTY502000502500250025252000200020002000
CarrierTUBELARGE T&RTUBELARGE T&RLARGE T&RTUBETUBELARGE T&RLARGE T&RLARGE T&RLARGE T&R
МаркировкаLS00LS00LS00LS00LS00SN74LS00NSN74LS00N74LS0074LS00LS00LS00
Width (мм)3.915.35.33.913.913.916.676.356.355.35.35.35.3
Length (мм)8.656.26.28.658.658.6519.5619.319.310.310.36.26.2
Thickness (мм)1.581.951.951.581.581.584.573.93.91.951.951.951.95
Pitch (мм)1.27.65.651.271.271.272.542.542.541.271.271.271.27
Max Height (мм)1.75221.751.751.755.085.085.082222
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачать
Parameters / ModelsSN74LS00D
SN74LS00D
SN74LS00DBLE
SN74LS00DBLE
SN74LS00DBR
SN74LS00DBR
SN74LS00DG4
SN74LS00DG4
SN74LS00DR
SN74LS00DR
SN74LS00DRE4
SN74LS00DRE4
SN74LS00J
SN74LS00J
SN74LS00N
SN74LS00N
SN74LS00NE4
SN74LS00NE4
SN74LS00NSR
SN74LS00NSR
SN74LS00NSRG4
SN74LS00NSRG4
SN74LS00PSR
SN74LS00PSR
SN74LS00PSRG4
SN74LS00PSRG4
Approx. Price (US$)0.18 | 1ku0.18 | 1ku
Bits44444444444
Bits(#)44
F @ Nom Voltage(Max), Mhz3535353535353535353535
F @ Nom Voltage(Max)(Mhz)3535
ICC @ Nom Voltage(Max), мА0.0220.0220.0220.0220.0220.0220.0220.0220.0220.0220.022
ICC @ Nom Voltage(Max)(mA)0.0220.022
Тип входаTTLTTL
Рабочий диапазон температур, Cот 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70
Operating Temperature Range(C)0 to 700 to 70
Output Drive (IOL/IOH)(Max), мА0.4/-160.4/-160.4/-160.4/-160.4/-160.4/-160.4/-160.4/-160.4/-160.4/-160.4/-16
Output Drive (IOL/IOH)(Max)(mA)0.4/-160.4/-16
Тип выходаTTLTTL
Package GroupSOICSSOPSSOPSOICSOICSOICPDIP
SO
SOIC
SSOP
PDIPPDIPSOSOSOSO
Package Size: mm2:W x L, PKG14SOIC: 52 mm2: 6 x 8.65(SOIC)14SSOP: 48 mm2: 7.8 x 6.2(SSOP)14SOIC: 52 mm2: 6 x 8.65(SOIC)14SOIC: 52 mm2: 6 x 8.65(SOIC)14SOIC: 52 mm2: 6 x 8.65(SOIC)See datasheet (PDIP)See datasheet (PDIP)8SO: 48 mm2: 7.8 x 6.2(SO)8SO: 48 mm2: 7.8 x 6.2(SO)8SO: 48 mm2: 7.8 x 6.2(SO)8SO: 48 mm2: 7.8 x 6.2(SO)
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
RatingCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalog
Schmitt TriggerNoNoNoNoNoNoNoNoNoNoNoNoNo
Technology FamilyLSLSLSLSLSLSLSLSLSLSLSLSLS
VCC(Max), В5.255.255.255.255.255.255.255.255.255.255.25
VCC(Max)(V)5.255.25
VCC(Min), В4.754.754.754.754.754.754.754.754.754.754.75
VCC(Min)(V)4.754.75
Voltage(Nom), В55555555555
Voltage(Nom)(V)55
tpd @ Nom Voltage(Max), нс2222222222222222222222
tpd @ Nom Voltage(Max)(ns)2222
RoHSСовместимНе совместимСовместимСовместимСовместимСовместимНе совместимСовместимСовместимСовместимСовместимСовместимСовместим
Бессвинцовая технология (Pb Free)НетДаНетДа
  • Designing with the SN54/74LS123 (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
  • Semiconductors> Logic> Gate> NAND Gate
На английском языке: Datasheet Texas Instruments SN74LS00
