Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LS125A — Даташит
СерияSN74LS125A
Четверные шинные буферы с выходами с 3 состояниями
Quadruple Bus Buffers With 3-State Outputs datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 6 фев 2002
SN74LS125ADSN74LS125ADBRSN74LS125ADBRG4SN74LS125ADE4SN74LS125ADRSN74LS125ADRE4SN74LS125ADRG4SN74LS125ANSN74LS125AN3SN74LS125ANE4SN74LS125ANSR
Статус продуктаВ производствеВ производствеВ производствеВ производствеВ производствеВ производствеВ производствеВ производствеСнят с производстваВ производствеВ производстве
Доступность образцов у производителяНетДаНетНетНетНетНетНетНетДаНет
N1234567891011
Pin1414141414141414141414
Package TypeDDBDBDDDDNNNNS
Industry STD TermSOICSSOPSSOPSOICSOICSOICSOICPDIPPDIPPDIPSOP
JEDEC CodeR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDIP-TR-PDIP-TR-PDIP-TR-PDSO-G
Package QTY50200020005025002500250025252000
CarrierTUBELARGE T&RLARGE T&RTUBELARGE T&RLARGE T&RLARGE T&RTUBETUBELARGE T&R
МаркировкаLS125ALS125ALS125ALS125ALS125ALS125ALS125ASN74LS125ANSN74LS125AN74LS125A
Width (мм)3.915.35.33.913.913.913.916.356.356.355.3
Length (мм)8.656.26.28.658.658.658.6519.319.319.310.3
Thickness (мм)1.581.951.951.581.581.581.583.93.93.91.95
Pitch (мм)1.27.65.651.271.271.271.272.542.542.541.27
Max Height (мм)1.75221.751.751.751.755.085.085.082
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачать
Parameters / ModelsSN74LS125AD
SN74LS125AD
SN74LS125ADBR
SN74LS125ADBR
SN74LS125ADBRG4
SN74LS125ADBRG4
SN74LS125ADE4
SN74LS125ADE4
SN74LS125ADR
SN74LS125ADR
SN74LS125ADRE4
SN74LS125ADRE4
SN74LS125ADRG4
SN74LS125ADRG4
SN74LS125AN
SN74LS125AN
SN74LS125AN3
SN74LS125AN3
SN74LS125ANE4
SN74LS125ANE4
SN74LS125ANSR
SN74LS125ANSR
Approx. Price (US$)0.23 | 1ku
Bits4444444444
Bits(#)4
F @ Nom Voltage(Max), Mhz35353535353535353535
F @ Nom Voltage(Max)(Mhz)35
ICC @ Nom Voltage(Max), мА0.0620.0620.0620.0620.0620.0620.0620.0620.0620.062
ICC @ Nom Voltage(Max)(mA)0.062
Тип входаTTL
Рабочий диапазон температур, Cот 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70
Output Drive (IOL/IOH)(Max), мА-2.6/24-2.6/24-2.6/24-2.6/24-2.6/24-2.6/24-2.6/24-2.6/24-2.6/24-2.6/24
Output Drive (IOL/IOH)(Max)(mA)-2.6/24
Тип выходаTTL
Package GroupSOICSSOPSSOPSOICSOICSOICSOICPDIPPDIPPDIPSO
Package Size: mm2:W x L, PKG14SOIC: 52 mm2: 6 x 8.65(SOIC)14SSOP: 48 mm2: 7.8 x 6.2(SSOP)14SSOP: 48 mm2: 7.8 x 6.2(SSOP)14SOIC: 52 mm2: 6 x 8.65(SOIC)14SOIC: 52 mm2: 6 x 8.65(SOIC)14SOIC: 52 mm2: 6 x 8.65(SOIC)14SOIC: 52 mm2: 6 x 8.65(SOIC)See datasheet (PDIP)See datasheet (PDIP)14SO: 80 mm2: 7.8 x 10.2(SO)
RatingCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalogCatalog
Schmitt TriggerNoNoNoNoNoNoNoNoNoNoNo
Technology FamilyLSLSLSLSLSLSLSLSLSLSLS
VCC(Max), В5.255.255.255.255.255.255.255.255.255.25
VCC(Max)(V)5.25
VCC(Min), В4.754.754.754.754.754.754.754.754.754.75
VCC(Min)(V)4.75
Voltage(Nom), В5555555555
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max), нс18181818181818181818
tpd @ Nom Voltage(Max)(ns)18
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимНе совместимСовместимСовместим
Бессвинцовая технология (Pb Free)ДаДаНет
  • Designing with the SN54/74LS123 (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Non-Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74LS125A
