Datasheet Texas Instruments SN74LV161284DGGR — Даташит
СерияSN74LV161284
МодельSN74LV161284DGGR
19-битный интерфейс шины 48-TSSOP от -40 до 85
SN74LV161284 datasheet
PDF, 359 Кб, Версия: C, Файл опубликован: 4 ноя 2002
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLV161284
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits19
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.8 мА
Output Drive (IOL/IOH)(Max)84/-14 мА
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
Technology FamilyLV-A
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)30 нс
  • Logic Solutions For IEEE Std 1284
    PDF, 111 Кб, Файл опубликован: 1 июн 1999
    Since the creation of IEEE Std 1284, designers have been using this signaling method to interface between the personal computer and peripheral devices. Bulky discrete components, such as termination and pullup resistors and capacitors, were used extensively. To integrate into single-chip solutions that comply with IEEE Std 1284, Texas Instruments (TI) offers three bus-interface devices that provid
Серия: SN74LV161284 (3)
  • Semiconductors > Logic > Specialty Logic > IEEE-1284 Parallel Port Interface (PPI)
На английском языке: Datasheet Texas Instruments SN74LV161284DGGR
