Datasheet Texas Instruments SN74LV161284 — Даташит
СерияSN74LV161284
19-битный интерфейс шины
SN74LV161284 datasheet
PDF, 359 Кб, Версия: C, Файл опубликован: 4 ноя 2002
SN74LV161284DGGRSN74LV161284DLSN74LV161284DLR
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНет
N123
Pin484848
Package TypeDGGDLDL
Industry STD TermTSSOPSSOPSSOP
Package QTY2000251000
CarrierLARGE T&RTUBELARGE T&R
МаркировкаLV161284LV161284LV161284
Width (мм)6.17.497.49
Length (мм)12.515.8815.88
Thickness (мм)1.152.592.59
Pitch (мм).5.635.635
Max Height (мм)1.22.792.79
Parameters / ModelsSN74LV161284DGGR
SN74LV161284DGGR
SN74LV161284DL
SN74LV161284DL
SN74LV161284DLR
SN74LV161284DLR
Bits191919
F @ Nom Voltage(Max), Mhz707070
ICC @ Nom Voltage(Max), мА0.80.80.8
Рабочий диапазон температур, Cот -40 до 85от -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА84/-1484/-1484/-14
Package GroupTSSOPSSOPSSOP
Package Size: mm2:W x L, PKG48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)48SSOP: 164 mm2: 10.35 x 15.88(SSOP)48SSOP: 164 mm2: 10.35 x 15.88(SSOP)
Technology FamilyLV-ALV-ALV-A
VCC(Max), В5.55.55.5
VCC(Min), В4.54.54.5
Voltage(Nom), В3.33.33.3
tpd @ Nom Voltage(Max), нс303030
  • Logic Solutions For IEEE Std 1284
    PDF, 111 Кб, Файл опубликован: 1 июн 1999
    Since the creation of IEEE Std 1284, designers have been using this signaling method to interface between the personal computer and peripheral devices. Bulky discrete components, such as termination and pullup resistors and capacitors, were used extensively. To integrate into single-chip solutions that comply with IEEE Std 1284, Texas Instruments (TI) offers three bus-interface devices that provid
Серия: SN74LV161284 (3)
  • Semiconductors> Logic> Specialty Logic> IEEE-1284 Parallel Port Interface (PPI)
На английском языке: Datasheet Texas Instruments SN74LV161284
