Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LVC02A-EP — Даташит
СерияSN74LVC02A-EP
Усовершенствованный продукт, четверной вентиль «Положительный-Нор» с 2 входами
SN74LVC02A-EP datasheet
PDF, 471 Кб, Файл опубликован: 14 мар 2007
SN74LVC02AMPWREPV62/06660-01XE
N12
Pin1414
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLVC02AMLVC02AM
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Parameters / ModelsSN74LVC02AMPWREP
SN74LVC02AMPWREP
V62/06660-01XE
V62/06660-01XE
Bits44
F @ Nom Voltage(Max), Mhz7070
ICC @ Nom Voltage(Max), мА0.010.01
Тип входаTTLTTL
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА24/-2424/-24
Тип выходаTTLTTL
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG14TSSOP: 32 mm2: 6.4 x 5(TSSOP)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Schmitt TriggerNoNo
Technology FamilyLVCLVC
VCC(Max), В3.63.6
VCC(Min), В22
tpd @ Nom Voltage(Max), нс6.5,5.56.5,5.5
RoHSСовместимСовместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC02A-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Gate Products
На английском языке: Datasheet Texas Instruments SN74LVC02A-EP
Публикации по теме
