Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LVC04A-Q1 — Даташит
СерияSN74LVC04A-Q1
Автомобильный каталог Hex Inverter
Hex Inverter datasheet
PDF, 791 Кб, Версия: B, Файл опубликован: 12 фев 2008
SN74LVC04AQDRQ1SN74LVC04AQPWRG4Q1SN74LVC04AQPWRQ1
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНет
N123
Pin141414
Package TypeDPWPW
Industry STD TermSOICTSSOPTSSOP
Package QTY250020002000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаLVC04AQLVC04AQLVC04AQ
Width (мм)3.914.44.4
Length (мм)8.6555
Thickness (мм)1.5811
Pitch (мм)1.27.65.65
Max Height (мм)1.751.21.2
Parameters / ModelsSN74LVC04AQDRQ1
SN74LVC04AQDRQ1
SN74LVC04AQPWRG4Q1
SN74LVC04AQPWRG4Q1
SN74LVC04AQPWRQ1
SN74LVC04AQPWRQ1
Bits666
F @ Nom Voltage(Max), Mhz100100100
ICC @ Nom Voltage(Max), мА0.010.010.01
Рабочий диапазон температур, Cот -40 до 125от -40 до 125от -40 до 125
Output Drive (IOL/IOH)(Max), мА-24/24-24/24-24/24
Package GroupSOICTSSOPTSSOP
Package Size: mm2:W x L, PKG14SOIC: 52 mm2: 6 x 8.65(SOIC)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
RatingAutomotiveAutomotiveAutomotive
Schmitt TriggerNoNoNo
Technology FamilyLVCLVCLVC
VCC(Max), В3.63.63.6
VCC(Min), В222
Voltage(Nom), В2.7,3.32.7,3.32.7,3.3
tpd @ Nom Voltage(Max), нс5.5,4.55.5,4.55.5,4.5
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74LVC04A-Q1
Публикации по теме
