Datasheet Texas Instruments SN74LVC161284DLR — Даташит
СерияSN74LVC161284
МодельSN74LVC161284DLR
19-битный интерфейс шины с выходами с 3 состояниями 48-SSOP от 0 до 70
SN74LVC161284 datasheet
PDF, 347 Кб, Версия: J, Файл опубликован: 15 фев 2005
Pin48
Package TypeDL
Industry STD TermSSOP
Package QTY1000
МаркировкаLVC161284
Width (мм)7.49
Length (мм)15.88
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Bits19
F @ Nom Voltage(Max)150 Mhz
ICC @ Nom Voltage(Max)0.8 мА
Output Drive (IOL/IOH)(Max)84/-14 мА
Package GroupSSOP
Package Size: mm2:W x L48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)3 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)40 нс
  • Logic Solutions For IEEE Std 1284
    PDF, 111 Кб, Файл опубликован: 1 июн 1999
    Since the creation of IEEE Std 1284, designers have been using this signaling method to interface between the personal computer and peripheral devices. Bulky discrete components, such as termination and pullup resistors and capacitors, were used extensively. To integrate into single-chip solutions that comply with IEEE Std 1284, Texas Instruments (TI) offers three bus-interface devices that provid
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Specialty Logic > IEEE-1284 Parallel Port Interface (PPI)
На английском языке: Datasheet Texas Instruments SN74LVC161284DLR
