Datasheet ТI SN74LVC16244 — Даташит
СерияSN74LVC16244
Datasheet Texas Instruments SN74LVC16244
16-битный буфер/драйвер с выходами с 3 состояниями
Datasheet
TSP
SN74LVC16244DGGRSN74LVC16244DLSN74LVC16244DLR
Статус продуктаСнят с производстваСнят с производстваСнят с производства
Доступность образцов у производителяНетНетНет
N123
Pin484848
Package TypeDGGDLDL
Industry STD TermTSSOPSSOPSSOP
Width (мм)6.17.497.49
Length (мм)12.515.8815.88
Thickness (мм)1.152.592.59
Pitch (мм).5.635.635
Max Height (мм)1.22.792.79
RoHSНе совместимНе совместимНе совместим
Бессвинцовая технология (Pb Free)НетНетНет
  • Simultaneous-Switching Performance of TI Logic Devices (Rev. B)
    PDF, 378 Кб, Версия: B, Файл опубликован: 23 фев 2005
    Simultaneous-switching noise can generate and propagate glitches in electronic systems. Therefore, system designers are faced with challenges to minimize simultaneous-switching noise, while increasing switching speed and improving signal quality. This report presents the performance of different TI logic devices under various simultaneous-switching conditions. Factors such as the number of bits sw
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC16244 (3)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Non-Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74LVC16244
Политика конфиденциальности
