Помощь в переводе проектов на ПЛИС азиатских брендов
Datasheet Texas Instruments SN74LVC16373ADLRG4 — Даташит
СерияSN74LVC16373A
МодельSN74LVC16373ADLRG4
16-битная прозрачная защелка типа D с выходами с 3 состояниями 48-SSOP от -40 до 125
SN74LVC16373A 16-Bit Transparent D-Type Latch With 3-State Outputs datasheet
PDF, 981 Кб, Версия: B, Файл опубликован: 5 фев 2014
Pin48
Package TypeDL
Industry STD TermSSOP
Package QTY1000
МаркировкаLVC16373A
Width (мм)7.49
Length (мм)15.88
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
3-State OutputYes
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)24/-24 мА
Package GroupSSOP
Package Size: mm2:W x L48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)6.4,4.2,4.9 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Latch
На английском языке: Datasheet Texas Instruments SN74LVC16373ADLRG4
