Datasheet Texas Instruments SN74LVC1G02-EP — Даташит
СерияSN74LVC1G02-EP
Усовершенствованный продукт Одиночный логический элемент «Положительный-Нор» с 2 входами
SN74LVC1G02-EP datasheet
PDF, 748 Кб, Файл опубликован: 2 июн 2006
SN74LVC1G02MDCKREPV62/06631-01XE
N12
Pin55
Package TypeDCKDCK
Industry STD TermSOT-SC70SOT-SC70
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаBUFBUF
Width (мм)1.251.25
Length (мм)22
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)1.11.1
Parameters / ModelsSN74LVC1G02MDCKREP
SN74LVC1G02MDCKREP
V62/06631-01XE
V62/06631-01XE
3-State OutputNoNo
Bits11
F @ Nom Voltage(Max), Mhz150150
Gate TypeNORNOR
ICC @ Nom Voltage(Max), мА0.010.01
Тип входаCMOS/TTLCMOS/TTL
LogicTrueTrue
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА32/-3232/-32
Тип выходаCMOSCMOS
Package GroupSC70SC70
Package Size: mm2:W x L, PKG5SC70: 4 mm2: 2.1 x 2(SC70)5SC70: 4 mm2: 2.1 x 2(SC70)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Schmitt TriggerNoNo
Sub-FamilyNOR GateNOR Gate
Technology FamilyLVCLVC
VCC(Max), В5.55.5
VCC(Min), В1.651.65
Voltage(Nom), В1.8,2.5,3.3,51.8,2.5,3.3,5
tpd @ Nom Voltage(Max), нс10.7,7.3,6,510.7,7.3,6,5
RoHSСовместимСовместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G02-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Little Logic Products
На английском языке: Datasheet Texas Instruments SN74LVC1G02-EP
