Datasheet Texas Instruments SN74LVC1G04-EP — Даташит
СерияSN74LVC1G04-EP
Усовершенствованный продукт с одним инверторным затвором
Single Inverter Gate datasheet
PDF, 728 Кб, Версия: A, Файл опубликован: 21 окт 2008
SN74LVC1G04MDBVREPV62/07625-01XE
N12
Pin55
Package TypeDBVDBV
Industry STD TermSOT-23SOT-23
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаSBKMSBKM
Width (мм)1.61.6
Length (мм)2.92.9
Thickness (мм)1.21.2
Pitch (мм).95.95
Max Height (мм)1.451.45
Parameters / ModelsSN74LVC1G04MDBVREP
SN74LVC1G04MDBVREP
V62/07625-01XE
V62/07625-01XE
3-State OutputNoNo
Bits11
F @ Nom Voltage(Max), Mhz150150
Gate TypeINVERTER BUFFERINVERTER BUFFER
ICC @ Nom Voltage(Max), мА0.010.01
Тип входаCMOS/TTLCMOS/TTL
LogicInvertingInverting
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА32/-3232/-32
Тип выходаCMOSCMOS
Package GroupSOT-23SOT-23
Package Size: mm2:W x L, PKG5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Schmitt TriggerNoNo
Sub-FamilyInverting Buffer/DriverInverting Buffer/Driver
Technology FamilyLVCLVC
VCC(Max), В5.55.5
VCC(Min), В1.651.65
Voltage(Nom), В1.8,2.5,3.3,51.8,2.5,3.3,5
tpd @ Nom Voltage(Max), нс13.9,8,5.7,4.513.9,8,5.7,4.5
RoHSСовместимСовместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G04-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Little Logic Products
На английском языке: Datasheet Texas Instruments SN74LVC1G04-EP
Публикации по теме
