Datasheet Texas Instruments SN74LVC1G17-Q1 — Даташит
СерияSN74LVC1G17-Q1
Автомобильный каталог Одиночный буфер триггера Шмитта
Single Schmitt-Trigger Buffer datasheet
PDF, 823 Кб, Версия: A, Файл опубликован: 9 апр 2008
SN74LVC1G17QDBVRQ1SN74LVC1G17QDCKRQ1
Доступность образцов у производителяДаДа
N12
Pin55
Package TypeDBVDCK
Industry STD TermSOT-23SOT-SC70
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаC17OC7O
Width (мм)1.61.25
Length (мм)2.92
Thickness (мм)1.2.9
Pitch (мм).95.65
Max Height (мм)1.451.1
Parameters / ModelsSN74LVC1G17QDBVRQ1
SN74LVC1G17QDBVRQ1
SN74LVC1G17QDCKRQ1
SN74LVC1G17QDCKRQ1
3-State OutputNoNo
Bits11
F @ Nom Voltage(Max), Mhz150150
Gate TypeSCHMITT TRIGGER BUFFERSCHMITT TRIGGER BUFFER
ICC @ Nom Voltage(Max), мА0.020.02
LogicTrueTrue
Рабочий диапазон температур, Cот -40 до 125от -40 до 125
Output Drive (IOL/IOH)(Max), мА32/-3232/-32
Package GroupSOT-23SC70
Package Size: mm2:W x L, PKG5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)5SC70: 4 mm2: 2.1 x 2(SC70)
RatingAutomotiveAutomotive
Schmitt TriggerYesYes
Special FeaturesIoff,down translation to Vcc,low power,Schmitt-triggerIoff,down translation to Vcc,low power,Schmitt-trigger
Sub-FamilyNon-Inverting Buffer/DriverNon-Inverting Buffer/Driver
Technology FamilyLVCLVC
VCC(Max), В6.56.5
VCC(Min), В1.651.65
Voltage(Nom), В1.8,2.5,3.3,51.8,2.5,3.3,5
tpd @ Nom Voltage(Max), нс14,9,8,714,9,8,7
RoHSСовместимСовместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G17-Q1 (2)
  • Semiconductors> Logic> Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G17-Q1
