Datasheet Texas Instruments SN74LVC1G3208-Q1 — Даташит
СерияSN74LVC1G3208-Q1
Каталог автомобилей Одиночный логический элемент положительного ИЛИ-И с 3 входами
Single 3-Input Positive OR-AND Gate datasheet
PDF, 801 Кб, Файл опубликован: 29 дек 2010
CLVC1G3208IDCKRQ1
Статус продуктаВ производстве
CLVC1G3208IDCKRQ1
N1
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаDGR
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Parameters / ModelsCLVC1G3208IDCKRQ1
CLVC1G3208IDCKRQ1
3-State OutputNo
Bits1
F @ Nom Voltage(Max), Mhz150
Gate TypeCONFIGURABLE
ICC @ Nom Voltage(Max), мА0.01
LogicTrue
Рабочий диапазон температур, Cот -40 до 85
Output Drive (IOL/IOH)(Max), мА32/-32
Package GroupSC70
Package Size: mm2:W x L, PKG6SC70: 4 mm2: 2.1 x 2(SC70)
RatingAutomotive
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power,combinational logic,configurable
Sub-FamilyConfigurable Logic
Technology FamilyLVC
VCC(Max), В5.5
VCC(Min), В1.65
Voltage(Nom), В1.8,2.5,3.3,5
tpd @ Nom Voltage(Max), нс17.5,7.6,5.9,4.2
CLVC1G3208IDCKRQ1
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
Серия: SN74LVC1G3208-Q1 (1)
  • Semiconductors> Logic> Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G3208-Q1
Публикации по теме
