Datasheet Texas Instruments SN74LVC1G79WDCKREP — Даташит
СерияSN74LVC1G79-EP
МодельSN74LVC1G79WDCKREP
Усовершенствованный продукт Одиночный триггер D-типа с запуском по положительному фронту 5-SC70 от -55 до 115
SN74LVC1G79-EP datasheet
PDF, 749 Кб, Версия: A, Файл опубликован: 16 апр 2009
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаCRR
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeFLIP-FLOP
ICC @ Nom Voltage(Max)0.01 мА
Тип входаCMOS/TTL
LogicTrue
Рабочий диапазон температурот -55 до 115 C
Output Drive (IOL/IOH)(Max)32/-32 мА
Тип выходаCMOS
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Sub-FamilyD-Type Flip-Flop
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)10.1,7,5,4.5 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G79-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Little Logic Products
На английском языке: Datasheet Texas Instruments SN74LVC1G79WDCKREP
Публикации по теме
