Datasheet Texas Instruments SN74LVC1G86QDCKRQ1 — Даташит
СерияSN74LVC1G86-Q1
МодельSN74LVC1G86QDCKRQ1
Автомобильный одинарный вентиль «исключающее ИЛИ» с 2 входами 5-SC70 от -40 до 125
SN74LVC1G86-Q1 Single 2-Input Exclusive-OR Gate datasheet
PDF, 834 Кб, Файл опубликован: 4 окт 2016
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
Маркировка16T
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeXOR
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
RatingAutomotive
Schmitt TriggerNo
Special FeaturesIoff, Down translation to Vcc, Low Power
Sub-FamilyXOR Gate
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)9.9 5.5 5 4 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G86-Q1 (2)
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G86QDCKRQ1
