Datasheet Texas Instruments SN74LVC1G97IDCKREP — Даташит
СерияSN74LVC1G97-EP
МодельSN74LVC1G97IDCKREP
Усовершенствованный конфигурируемый многофункциональный шлюз 6-SC70 от -40 до 85
SN74LVC1G97-EP datasheet
PDF, 745 Кб, Версия: B, Файл опубликован: 18 фев 2005
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаCSR
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeConfigurable
ICC @ Nom Voltage(Max)0.01 мА
Тип входаCMOS/TTL
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Тип выходаCMOS
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Sub-FamilyConfigurable Logic
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)14.4,8.3,6.3,5.1 нс
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G97-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Little Logic Products
На английском языке: Datasheet Texas Instruments SN74LVC1G97IDCKREP
Публикации по теме
