Datasheet Texas Instruments SN74LVC1G98-Q1 — Даташит
СерияSN74LVC1G98-Q1
Автомобильный каталог Конфигурируемые многофункциональные ворота
Configurable Multiple-Function Gate datasheet
PDF, 762 Кб, Версия: C, Файл опубликован: 10 апр 2008
SN74LVC1G98QDCKRQ1
Статус продуктаВ производстве
SN74LVC1G98QDCKRQ1
N1
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаCWO
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Parameters / ModelsSN74LVC1G98QDCKRQ1
SN74LVC1G98QDCKRQ1
3-State OutputNo
Bits1
F @ Nom Voltage(Max), Mhz150
Gate TypeCONFIGURABLE
ICC @ Nom Voltage(Max), мА0.01
LogicTrue
Рабочий диапазон температур, Cот -40 до 125
Output Drive (IOL/IOH)(Max), мА32/-32
Package GroupSC70
Package Size: mm2:W x L, PKG6SC70: 4 mm2: 2.1 x 2(SC70)
RatingAutomotive
Schmitt TriggerYes
Special FeaturesIoff,down translation to Vcc,low power,configurable
Sub-FamilyConfigurable Logic
Technology FamilyLVC
VCC(Max), В5.5
VCC(Min), В1.65
Voltage(Nom), В1.8,2.5,3.3,5
tpd @ Nom Voltage(Max), нс16.4,9.3,7.3,6.1
SN74LVC1G98QDCKRQ1
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G98-Q1 (1)
  • Semiconductors> Logic> Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G98-Q1
Публикации по теме
