Datasheet Texas Instruments CLVC2G126MDCUTEP — Даташит
СерияSN74LVC2G126-EP
МодельCLVC2G126MDCUTEP
Буферный вентиль с двойной шиной и выходами с 3 состояниями 8-VSSOP от -55 до 125
Dual Bus Buffer Gate With 3-State Outputs, SN74LVC2G126-EP datasheet
PDF, 760 Кб, Файл опубликован: 12 дек 2013
Package TypeDCU
Industry STD TermVSSOP
Package QTY250
CarrierSMALL T&R
МаркировкаCEPR
Width (мм)2
Length (мм)2.3
Thickness (мм).85
Pitch (мм).5
Max Height (мм).9
3-State OutputYes
Bits2
F @ Nom Voltage(Max)150 Mhz
Gate TypeBUFFER
ICC @ Nom Voltage(Max)0.01 мА
Тип входаCMOS/TTL
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Тип выходаCMOS
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 6 mm2: 3.1 x 2(VSSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)15.2,8.6,6.8,5.5 нс
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
Серия: SN74LVC2G126-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Little Logic Products
На английском языке: Datasheet Texas Instruments CLVC2G126MDCUTEP
Публикации по теме
