Datasheet Texas Instruments SN74LVCH16373ADLG4 — Даташит
| Серия | SN74LVCH16373A |
| Модель | SN74LVCH16373ADLG4 |
16-битная прозрачная защелка типа D с выходами с 3 состояниями 48-SSOP от -40 до 125
SN74LVCH16373A 16-Bit Transparent D-Type Latch With 3-State Outputs datasheet
PDF, 960 Кб, Версия: N, Файл опубликован: 24 июл 2014
Купить SN74LVCH16373ADLG4 на РадиоЛоцман.Цены — от 61 до 81 ₽12 предложений от 12 поставщиков Микросхема Логический замок, 16Bit Transparent D-Type Latch With 3-State Outputs 48-SSOP -40℃ to 125℃ | |||
| SN74LVCH16373ADLG4 Texas Instruments | 61 ₽ | ||
| SN74LVCH16373ADLG4 Texas Instruments | 72 ₽ | ||
| SN74LVCH16373ADLG4 Texas Instruments | по запросу | ||
| Pin | 48 |
| Package Type | DL |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 25 |
| Carrier | TUBE |
| Маркировка | LVCH16373A |
| Width (мм) | 7.49 |
| Length (мм) | 15.88 |
| Thickness (мм) | 2.59 |
| Pitch (мм) | .635 |
| Max Height (мм) | 2.79 |
| Mechanical Data | Скачать |
| 3-State Output | Yes |
| Bits | 16 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.02 мА |
| Рабочий диапазон температур | от -40 до 125,-40 до 85 C |
| Output Drive (IOL/IOH)(Max) | 24/-24 мА |
| Package Group | SSOP |
| Package Size: mm2:W x L | 48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVC |
| VCC(Max) | 3.6 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
| tpd @ Nom Voltage(Max) | 4.9,4.2 нс |
- Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVCH16373A (8)
- Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Latch
